Ok, so a few updates.
After allowing the new pump to run overnight, I can now see speeds up to 70-72 GPM, which I don't believe I've ever seen before. It appears that after running for awhile, flows go up - maybe air working its way out of the system?
At full speed, the pump basket does completely fill with water (after some bit of time). At lower speeds (under 2000), I have noticed it only about half full.
The pump has a pressure reading of 39 PSI.
I took apart the previous pump. I don't see any signs at all of clogs in the impeller. Seems clean as can be.
Some pics below:
Return manifold:
In this picture, the spa has 2 lines (valved) up on the right by the wall. At the bottom is the start of the pool returns. The Intellivalve on the left switches between pool returns and In Floor system.
Some pics below:
Return manifold:
