- Apr 7, 2019
- 19
- Plaster
- CircuPool RJ-30
Hi everyone,
My pool has been running four seasons and I have just realized my filter pump is capable of flow control, an Intelliflo VSF. I have an EastTouch controlling the pump, all setup by the pool contractor. This controller does not support "flow" (gpm) control, only "speed" (rpm). If I wanted to control the "flow" I can do it through the pump interface panel and just disconnect the comms to the EasyTouch. No problem, I can handle that. I will be installing a Circupool SWCG soon and want to know what you guys think of controlling it. The easiest, by far, would be to leave the pump control to the EasyTouch and just power the SWCG from the contactor in the EasyTouch panel. Would "flow" control benefit me in any appreciable way? Other than being kinda neat. I may be way overthinking things, but a closed loop control system is better than an open loop, especially if the equipment is already there. Any ideas on a good method to control this system with the above mentioned equipment?
