- Jun 10, 2009
- 336
- Plaster
- Pentair Intellichlor IC-40
I checked the pump and limited are set to 3450 rpm and 80gpm, however when I go into intellicenter app and put it at anything higher than 30gpm it will not go as you can see on the screen shot. When it starts priming set to 3450 and it goes that high without issue.
What could be causing this?
Thanks!
Thanks!
