N,
Color changing LED lights have a lifespan of about 12 nanoseconds...
I have three pools that all have EasyTouch systems with IntelliFlo pumps and SWCGs. I have had them for a "total" of over 25 years and have had no IntelliFlo problems, lost two IC40's but that was expected as one was about 9 years old and the other was over 7 years old. They typically last 5 to 7 years.
My next-door neighbor took a direct lightning strike, and it blew his water heater apart and did a ton of damage to his house. I got what was left over. At the time I had ScreenLogic
hardwired to my house network. Took out the main card in the EasyTouch, SWCG, Protocol Adapter, plus my modem, etc. Pentair came and fixed all of their stuff under warranty. That was about 5 years ago.
I am a pretty hard-core Pentair kind of guy...
Since your pool is so new, I'd call your pool builder and have them come and fix it. They generally will have a Pentair come out.
Since the lights work, that tells me that the main card is ok.
I suspect a loose wire at the J20 (com port connection). You can check that by dropping the top door of the EasyTouch down. J20 will have a cable that goes to the Surge card on the back wall of the EasyTouch. This connects the com port connections on the surge card to the main card. (Only one com port, just different points you can connect to.)
Show us some pics of the back of the card.
