Intelliflo pressure limit reached error
fwb
Active member
Jun 8, 2017
26
Las Vegas
My flow to the pool has dropped to almost zero, even after cleaning and replacing the filter. PSI on the filter tank reads 16, which is just below the "start" mark and well below the "clean" mark, so the problem is elsewhere. Where is the pressure sensor on the pump itself? Does it just sense the torque in the impeller? Trying to figure out if this is a clog on my suction side down the line from my skimmer basket, or something in the pump itself. Can I use a normal plumbing snake through my lines from my skimmer port to the pump? I tried blasting water through it with a hose but couldn't get a strong seal.
mas985
13,228
Pleasanton, CA
There is no pressure sensor on the pump. The pump drive determines the effective pressure based upon the RPM and Watts. If the watts is too low for a given RPM, the error will occur because the drive thinks the pump is under a high restriction which it probably is.
What is the RPM and Watts for the filter at 16 PSI?
Is there any air in the pump basket?
