Intelliconnect Problem with Intelliflo
bubby4113
16
South Carolina
Hi All -
I’ve been using an Intelliconnect with my Intelliflo and recently received an alert about a communication problem.
My pump still functions but I obviously cannot change the settings remotely now. It seems relay 1 is empty, which I don’t remember being the case when I set it up.
Should relay 1 be set up as the Intelliflo? If so, how do I properly do that again? Pentair customer service is closed and I work about thr freezing temps tonight and was going to run my pump at low speed all night.
Have you tried powering off the Intelliconnect and your equipment? I've had off and on problems for the last four years. Right now I can't control the IC40 from the app. Pentair tech support says they know and they're working on it. I finally disconnected the RS485 wire so I could control it from the panel. You might try that with your Intelliflo, if restarting everything doesn't get it going. Controlling the Intelliflo from the panel is not much fun, I know, especially if you're dealing with the arctic blast.
Hello, I just registered to post here after having this exact problem for months with no resolution in sight. Were you able to solve your connection problem? Mine seems to be getting worse now.
