- May 17, 2017
- 181
- Plaster
- Pentair iChlor 30
Still learning this automation system but I came across the pump overides when I discovered the pump wasnt scheduled to be running yet it was. When I looked at my app under the pump it showed that none of my schedules were active, as it should but at the bottom it said in pump override. I dont really see any settings on the app in regards to pump override. The only changes I can make to it are pump speed.
I am assuming it has some kind of built in override for the heat pump as well as the SWG? Is there a way to shut it off?
Thanks
Thanks
