Intellichlor40 stuck on 100%, no automation
May 13, 2013
21
Bentonville, AR
Hi everyone - Needing some wisdom from the group. At the end of last season our Intellichlor 40 somehow got stuck on 100% output and the flow sensor died. This Spring I replaced the flow sensor, now the diagnostic mode on the the 40 shows all green but I can't adjust the output using the +/- or Boost buttons. I searched the forum for similar situations but they all tie back to a malfunction with an automation system, which we don't have. Equipment pics attached
Is it possible my control center suddenly thinks an automation system is connected and thus the +/- lockout? And if so, anyway to bypass or deactivate that mode? I've checked the manuals for the 40 and the power center but I'm not seeing any obvious solutions. Any other scenarios or solutions i should consider? Thanks in advance!!!
Not sure if it matters but diagnostic shows the chlor40 is at 60% of it's lifespan.
Currently it's a juggling act of connecting and disconnecting the chlorinator every day so i don't over-chlorinate while keeping the pump/filter running.
Thanks!
7,
I think your cell is bad, but I'd want to check that nothing is connected to the com port inside the Power Center..
Show us a pics of the card inside the power center.
Sorry,
