My IC 40 gives me a red light indicating that the flow rate is too low. But I am certain that the rate is ok - I’ve run my pump in prior years at lower rates and the IC40 has been fine.
When I increase the flow rate to much higher - it works ok. It is just not activating at lower speeds.
Is there a way to adjust the sensitivity of the IC 40 - I see I little strip that hangs done in the way of the water which I think is the flow sensor. It just looks like a simple switch.
