Intellichlor IC20 Problem
d12e111
8
Markham, Ontario
Moved from HERE
Hi All - I have the same problem with my IC20 unit. This is the beginning of the 4th year using my unit and it only says that I've used 4000hrs so I find it a little early for me to buy a full replacement. Even though it doesn't say low salt, I'm going to try to add another bag of salt and see if the flash goes away. How long should it take after I add the extra bad of salt. Any feedback would be greatly appreciated!
Yes, add liquid chlorine until you get the SWG running.
Wait till you get your K-1766 test kit before adding more salt.
What is your water temperature?
Cell still flashing, salt is at 3600, Just checked the Manufacturer date and its from March 2018. which make sense as I had my pool installed July of 2018. 3-4 years just seems like such a short span as well as only using 4000+ hours. Sounding more like my cell is dead. Thoughts anyone?
