- May 23, 2015
- 25,728
- Plaster
- Pentair Intellichlor IC-60
For a flow switch, polarity doesn’t matter. It’s simply closing the circuit between the black and red wires.
Is that how Pentair says to plumb the supply and return piping into the flow cell
What’s that thing between the supply and return ports, a check valve?? I don’t think there’s enough of a pressure differential across that pipe to get any flow. I would take the supply side tube and hook it up to the discharge port on the pumps wet end (there’s a 1/4” plug there) as that would be the point of maximum pressure and then the return tube would be plumbed somewhere after your equipment and just before the water goes below ground to the pool.
