Help. I'm at my wits end trying to figure out why my Pentair Intellichem is reaching its pH feed limit about every other day even though I believe with the programmed settings it should never get reached. This issue has been going on for a year and conversations with Pentair support and technician visits haven't remedied the situation. We didn't have this issue when the system was first installed.
New intellichem board and pH and ORP (chlorine) probes were installed 3 mos. ago. (Jan. 2022)
This is my first post. I hope I've provided the necessary information for you to help me. Thanks in advance.
Intellichem pH settings:
Paper test strips & water tests seem relatively consistent with intellichem so I don't think there is a probe issue.
Had the water tested a couple of days ago:
Our setup:
Phoenix, AZ; Pool start up: March 2019
11k gal pool/spa combo - outdoor
Basalt Waterwall (which goes 24 hrs/day fed by separate VSF pump (Pentair Intelliflow #011056)
Pool pump (Pentair Intelliflow #011056) runs 4am - 7pm then goes lower flow for Spillway between spa and pool which runs 7pm-3:58am
Pentair IntelliChem water chemistry controller (p/n522622) with acid/chlorine 4 gallon container use w/2 pump system (521378)
Pentair EasyTouch 4 Pool/Spa Control System (p/n520538)
Pentair Screenlogic2 Bundle Smart Phone Tablet compatible Interface protocol adapter (p/n52210)
Filter - Pentair Clean & Clear Plus Cartridge Filter p/n160332 Model CCP 520)
Gas Heater - Pentair (P/N460736-HTR 400 Mastertemp)
Heat Pump - Aquacal Heatwave Superquiet electric heat pump 110K BTU Heat/cool (Model:120ARDSBPR)
Valve actuator 2 p/n263045
Lights: Paramount ParaGlo3” color LED for spa and 2 Paramount ParaGlo6” color LED for pool
Paramount inground pool cleaning
Wet Edge Pebble Finish - Dark Gray
Dose: 4 ounces
Max Dose/Day: 120 oz (intentionally set more than what system can dose with 4 oz dose and 1.5 hr mix time )
Mixing Time: 1 hr 30 minutes (Therefore Max. 16 doses per 24 hours 4 x 16 = 64 oz. max)
Limit Clear - 24 hours (previously have tried "Power on" to clear but that didn't seem to make a difference)
2 pumps on system (see below) Filter is set to run 15 hrs. per day
Total/Free Chlorine - 1.5 (low end - raised Intellichem ORP setpoint a bit after getting this result)
pH - 7.8 (runs high because I can't always get to clear the feed limit)
Total Alkalinity - 96 ppm
CYA - 37 ppm
Calcium Hardness - 274
TDS - 100
Our setup:
