IntelliChem Dosing
H2ObiWan
1
Estero, FL
I'm using Home Assistant with the Pentair IntelliCenter integration and would like to be able to know when the acid pump and SWG are on to monitor dosing. Since this information is not available via the integration, I was wondering if there was another way to do this. I was looking at using the IntelliChem relays, since one is used for the pump. However the SWG is turned on via a control message. A light sensor on the SWG LEDs seems like a kludge. Any ideas are appreciated. TIA
Welcome to TFP.
A kludge may be your only option if you really need to know.
Implementing nodejs to give my HA system (not Home Assistant) access to what my pool is doing is a "someday" goal. There might be something there for your application.
