Good morning... I'm installing the Intellicenter with IC60 to my existing system which currently has a Pentair Superflo VS. After reading the documentation and threads here, I totally agree that the instructions are total garbage on how to hook this up.
A couple of questions:
1. my pump was manufactured BEFORE 11/2020, so does this mean I cannot use the 353129Z cable to connect to the Intellicenter for control? I've seen a few write ups that use that cable with the Easytouch system to control various speeds through the relays
2. What is the proper way to wire this pump, directly to the breaker or through the relay - most information I've found on this only indicates how to wire up Intelliflo pumps
Thanks so much!
Thanks so much!
