Howdy IC users, wondering if someone with a heater and a valve can confirm the function of the BP_VLV programming when used with heat? I'd like to know if the IC integrates any delays into the programming when calling for heat and an actuator is connected to the BP_VLV connection.
Background, I am re-plumbing the pad and replacing the heater. I wanted to use this config, but since I do not have an IC and only a EasyTouch I wanted to see the behavior of the valve with the IC.
Ex: When heat is called, does the valve open for heater (Bypass closed), wait 30 seconds, then enable heat?
When turning off the spa, does the IC system cooldown heater by pumping water for N Minutes then close heater (Bypass open)?
Slightly more detail here Automated Heater Bypass
