- May 7, 2021
- 101
- Vinyl
- Pentair Intellichlor IC-40
Hello, when my PB setup my IntelliCenter schedule (pool installed last fall), they just created a single 24/7 schedule for pool/heater.
I'm looking to make some changes and could use some help. What I'd like to have is 3 schedules for my pump:
My first question is what exactly are the current "Pool" and "Heater" circuits that are attached to my pump? I see "Pool" listed under "Aux-Circuits", is this kind of a default circuit? I don't see a "Heater" circuit configured anywhere, is this just available because I have a heater configured? I do notice that regardless of what the "Pool" pump speed is, when the heater is on, the "Heater" speed takes precedence. This isn't a problem (I like this), I am just curious.
Here's what I'm thinking of doing:
I hope someone can help, thanks!
Kevin
- "Day" 8am-6pm, specific RPM, heater enabled
- "Evening" 6pm-9pm, specific RPM, heater disabled
- "Night" 9pm-8am, specific RPM, heater disabled
- Create "Evening" and "Night" feature circuits
- Add the above new circuits to my pump and configure the desired RPM for each
- Adjust the "Pool" circuit on my pump to my desired "day" RPM
- Adjust my current schedule (Pool) to only run between 8am and 6pm (keep "Heat Source: Heater")
- Add an "Evening" schedule, choose my "Evening" feature circuit, configure to run between 6pm and 9pm, and choose "Heat Source: OFF"
- Add a "Night" schedule, choose my "Night" feature circuit, configure to run between 9pm and 8am, and choose "Heat Source: OFF"
Kevin
