So here's my dilemma, I'm very confused by the intellicenter and how to program it. I have an IPS8 Here's what I want to do:
I guess first off, which is the best way to program? At the panel, on my phone or laptop?
1) I found the infinity edge feature, but need to do the following: Program it to close the main drain, open the infinity basin drain, open the infinity returns in the pool (actuators), increase the pump rpm for approximately 30 minutes to raise the level of the pool, then reduce it to a lower rpm to maintian the flow.
1A) can i use the return and intake connections for 2 of the drain actuators and the third actuator needs to open the infinity return. Or do I need to order an additonal board?
2) I have bubblers on my zero entry and will need to open a valve for this as well as a feature I'm guessing, so I'm not sure if I can install 4 actuators on the ips8. I also want to be able to turn the bubblers on and turn the pool lights on at night, is this possible to have 2 different bubbler features and how again do I program this.
3) What does the spa icon do without a spa, can I somehow use this for the infinity edge or just ignore it.
Anyways, the literature is very confusing and any help would be greatly appreciated. The programming piece shoud be easier and maybe on a computer connected to it would make my life a bit easier. Thanks. Have a great weekend.
