I came home to find that my intelliflo vs pool pump wasn’t running per the schedule today.
I checked the IntelliCenter, and it showed the pump was on per the schedule, but when I checked the pump status, it said “Lost connection”.
I checked the display on the pump, and it showed RPM... not “Display inactive” even though it is in Auto mode.
I checked the lights and other features plugged into the intellicenter and they all work. However, I have another Intelliflo VS pump used for a waterfall feature and I can not turn it on via the intellicenter. I checked it’s status and it says lost connection. The pump display shows RPM, same as the main pump.
I am able to start both pumps manually from the display, even though the intellicenter is in Auto mode.
this just happened overnight. We did have a bad electrical storm yesterday and I got home late and didn’t see the pool, so not sure if it might have knocked something out?
I have turned off/on the main breaker in the house to the intellicenter and have turned off/on all the breakers on the intellicenter and reset the panel. Still no connection to pumps.
system is less than a year old, so I can call my Pentair rep, but thought I would check here for anything obvious. I have manually turned the pump on, so the pool doesn’t turn green while I try to get the connection issue resolved.
thanks again for your help in advance.
