Hi all.
I'd like to wire ground landscape lighting into my intellicenter so I can control from my phone and run on a schedule. I already have 4 low voltage lines running from different areas around my pool converging at the panel.
Pictures of my panel are below. All breakers currently off for the winter except:
- 2nd to last one, which provides power to a yard outlet and line voltage yard light fixture (yard light is wired through one of the relays, so I can control from phone). Outlet has constant power.
- last one, which powers the intellicenter itself
Panel has an existing transformer on outside for the 4 LED pool lights (breaker for this is currently off)
What do you suggest as the easiest way to wire in the new landscape lighting? It will probably be a total of 10-15 LED path lights and uplights in various locations. Do I need a new breaker (dedicated circuit) or can I easily tap into an existing one?
Also any suggestions on which transformer to buy? I do electrical work but mostly indoors, not as much experience on the pool panel.
thanks
thanks
