Intellicenter firmware 2.017 - Filter pump will not turn on
JohnS530
12
Northern California
My OCP just asked me to update to Firmware 2.017.
Now my filter pump will not turn on.
Pump: Pentair Intelliflo VF pump 011012.
The display on the pump says: Display Not Active, which is normal.
If I put the panel into Service mode, I can operate the pump normally, using the pump panel.
If I roll back the firmware to 1.067, the pump works fine.
I do hear a quiet "click" on the pump panel about every 30 seconds. Any ideas?
When you go back to 2.017 check that a pump speed is set for the POOL circuit under the PUMPs configuration.
