- Jan 2, 2018
- 563
- Fiberglass
- Pentair Intellichlor IC-60
I have a Pool only, no Spa. Haven't been able to find much detail of what's available when configuring a Spa other than using 2 activators to change the suction & return lines. So, just curious if I could set up my pool's seat jets as a pseudo-spa as an alternative to Groups.
Return actuator: similar to a "real spa" - I'd change from my pool's return line to the jet's water line.
Suction actuator: replace with one on a valve limiting flow to solar panels when pump goes to the higher speed needed for jets
Guessing these are part of "real spa" config:
Pump speed: possible to add a delay so the Solar flow limiting (Suction replacement in this case) actuator has fully repositioned?
Blower
SWG: thought I read somewhere that this is auto decreased or turned off in Spa Mode. At any rate, is it controllable here?
Heater: is the solar left as defined in Pool mode? Or does it have to be redefined? Or is it even available in Spa mode?
Blower
