Intellicenter and Microbrite pool light color issues.
AZRider
155
Surprise , AZ
Pentair Intellichlor IC-40
Just started up a new pool and having automation issues. I have a Intellicenter i8PS and 3 microbrite color led lights. I went through manual several times and cannot get the colors to change. They are stuck on White. Initial startup one was cycling through colors but has since synced with the others. I have tried changing colors from Panel and App nothing seems to work. I have searched for videos, but all are older systems with different menus. Anyone know what I can be doing wrong?
Check that the Circuit Function on your light circuits is set to the correct type.
For Microbrite color lights set Circuit Function to Globrite.
Thanks ajw22, It was not programmed correctly for the microbrites I called Pentair was on hold an hour. They transferred me to the Pentair Intellicenter support team, he literally stepped me through the process in 2 minutes. None of the steps he had me perform were in the manual. In the end I can control the colors now.
