- Jun 8, 2020
- 590
- Plaster
- Pentair Intellichlor IC-40
My water softener loop passes right behind where our pool is going, and we're having a manual fill valve installed, which will fill through the water fall feature. The pool builder is suggesting I fill the pool with non-softened water, and also plumb the fill into the non-softened water line as well. They say if I use the water coming out of my water softener, it won't have enough calcium and will leech it from the plaster.
I was planning to fill with the softened water, and add calcium .. and have plenty of time to research and decide on that ... but for plumbing concerns, I'll need to make a decision fairly quickly on which line to tap into for the manual fill valve.
So what would be best to go with here?
