- May 3, 2007
- 17,013
- Plaster
- Hayward Aqua Rite (T-15)
Unfortunately, most medium and high high pumps do not publish flow rates that high in the head curves so it is uncertain if they could achieve that. Theoretically, they could with low head but the pump itself adds a certain amount of head loss so even if the plumbing were zero head loss, there is still head loss in the pump and the pump would max out at some flow rate. I suspect this is the reason that most pumps don't show flow rates above 180 GPM. The 3 HP Northstar goes to 180 GPM but at 60 feet of head. So it is not clear what happens to many of these pumps above the published levels and extrapolation can be erroneous.
The Pentair waterfall pumps are very low head waterfall pumps. The Hayward Tristars have good flow at higher head values but the specs start at 40 ft of head so it is difficult to say what happens at lower head. Discussion with the pump manufacture may help but I suspect that they don't even measure the performance beyond what is published in the head curves.
Another option is to use two matched parallel pumps. You can get away with 2 lower HP pumps while doubling your flow rate for a given head loss. A detailed analysis of this type of configuration is a bit tricky but can be done. The pumps see the same head loss which is determined by their combined flow rates. One easy approximation is to assume a single pump with plumbing of 2.3" diameter or 3.6x the equivalent length and then double the resulting flow rates. So a single pump with 2.3" plumbing will have the same head loss as a parallel pump system with 3" plumbing. So for example:
[EDIT] Corrected these numbers such that the plumbing would yield 26 feet of head at 175 GPM.
A single 3/4 HP Whisperflo with 2.3" plumbing yields 94 GPM @ 30 ft of head so two pumps with 3" plumbing would give you 188 GPM at with the same 30 ft. of head.
A single 1 HP Whisperflo with 2.3" plumbing yields 108 GPM @ 37 ft of head so two pumps with 3" plumbing would give you 216 GPM at with the same 37 ft. of head.
The pumps are still running at a low head loss but it is within the operating range of the pump this way. The pumps will run quieter than a single high HP pump and with less energy use (2x1.3kw vs 3.1 kw for 3HP). The downside of course is the cost of two pumps. However, this technique could also be applied to lower cost less efficient pumps as well such as the Pentair Superflo.
BTW 3" 90's are closer to 8 feet of straight pipe.
