Hello Everyone,
I have a 20x40 vinyl pool with a sand filter(approx 35000 gallons). The vinyl is going to be replaced in a week or so, and the wife wants to switch to salt water. I've heard good and bad, but went ahead and got the AquaRite with the T-15 cell. There is not alot of room in the plumbing(attaching link to picture). So, I'm hoping the valves will not be too bad, just cut out the old and replace with new non-metal ones. But with the size of the salt cell and flow switch I had some questions. As you can see, the pipe leaving the sand filter back to the pool only has about 10" before is 90's to the ground. So, I was thinking I could cut the pvc close to where it leaves the sand filter, extend that out to put in the salt cell, then 90 it back twice, coming back toward the house and on the return piece put on the flow meter. Then back under ground. Will this work? Or too many turns? Any suggestions?
Link to picture: 20170714_161656.jpg - Google Drive
Thanks.......
Gene
Thanks.......
Gene
