First, I am kinda familiar with SWG, I have downsize to a 15,000 gallon pool from a 65K with dual SWG setups. I have replaced the filter, pool pump and added the AQR3, along with some re-plumbing. Followed the instructions for the AQR3 and double checked to make sure it was set to a T3 cell. Ran the unit for 24 hours the first run, set the % desired to 80%. Tested the water, no chlorine registered. So I then set to Super Chlorinate, again no chlorine registering. Even took sample to PaP for testing. Added 2 bags of Salinity, set desired level to 100%, 2 days later, tested no chlorine. Going on 2 weeks now with the same results. Diagnostic Display: 86, 26.8, 3.16, 100, -3600, AL-0, 1.59, t-3. Last test on 6/7/19 Chlorine 0.00, pH 7.4, TA 110, CH 500, Stabilizer 100, Salt 3400. Hayward support is lagging in that department.
Apologies for the lengthy first post, but I am at a lost and very frustrated! Never had this much of a problem with my BIG pool! I guess it is true, it is always the "little" things that get you. Certainly appreciate any and all suggestions or input.
