I purchased an Intex above ground pool- I have the 24 x 12 x 52 and want to make I'm doing the installation correctly. We are removing the dirt to level from the lowest point and have removed all the sod, etc.
1. I was planning to use the foam core board under the bottom. Is this correct? Owens Corning FOAMULAR 150 1 in. x 4 ft. x 8 ft. R-5 Scored Square Edge Rigid Foam Board Insulation Sheathing-20WE - The Home Depot
2. Do I use regular duct tape to tape the seams?
3. If I'm using the foam core board, do I also need sand or other base, or can I just put the foam core board directly on the ground? I'm in the Houston area and we have really heavy clay soil but also tons of rain.
4. Pavers- I purchased the really thick pavers. Do I level these with the ground or leave them an inch above to accommodate the foam core?
5. Tarp- does the tarp go over the ground before the foam core, on top of the foam core, should it cover the pavers or no, what type of tarp?
Thanks so much!
Sarah
Thanks so much!
Sarah
