- Jun 30, 2021
- 33
- Vinyl
- CircuPool RJ-30 Plus
I decided I needed additional help finishing up the install of my pool (and I wanted to make sure it was done right) so I went with someone who used to be a certified pool operator/installer who was taking side work. Huge mistake. He didn't follow (or read) directions, even argued with me when I tried to have him follow directions. I should have fired him on the spot. He didn't even compact the sand bed so now it moves/sinks as you walk around on it!
Now I have the pool wall up and the liner in, and the pool wall slipped out of the bottom track, in fact, I am pretty sure he knew this had happened and just did not tell me. In other areas he even used masonry sand/water to backwash under the track, even though I had recycled concrete 3/8" minus and a plate compactor for any areas that weren't level!
From what I can guess, there is one area of the pool that is slightly unlevel and I need to raise the track up. The track isn't even level, it is angled slightly outwards. It is really hard to work with because the sand is pushing on the other side. To make things harder the pool is sunk half way into the ground so it is hard to get at the pavers. I even considered just throwing out / selling the pool for awhile.
What would you guys do? Should I lift the track up to level (maybe with plastic shims?) and backfill with a small amount of concrete? would that secure the track? I'm assuming I need to remove the liner. Possibly the pool wall? I don't know what to do with the pool foam coves and the sand resting against the wall, rip them out / pull them back?
In the pictures provided, note that the wall is obviously out of one track, and it is not down all of the way in another area of the track.
My permits expire at the end of the month too.
