Recently purchased a home with above ground pool. Previous owner obviously did not test water chemistry just added chlorine and clarifiers. Here is what I am getting using the TF-Pro test kit.
CH = 125
PH = 6.6
Chlorine = 0
When I test ALC, I use 25ml test water, add 2 drops R-0007, stir then add 5 drops R-008, the test water is bright red!
Does this mean my water is high or low in ALC?
Thank you,
Lakelizard
CH = 125
PH = 6.6
Chlorine = 0
Thank you,
Lakelizard
