I have a small (4500 gal) pool which is having its liner changed. Once done, I'll fill it with municipal water. How should I proceed to get this water to proper chemical balance? I assume I have to dump in some chlorine, some CYA, and some salt (I have an SWG). Can I do rough calculations for how much of what to add and then fine-tune based on testing? I probably won't run the SWG till the salt and the chlorine numbers are good -- is that the right way to go about it? I have the TFTest kit.
Would it be also fine to add some dichlor to get both chlorine and CYA and then add liquid bleach and CYA separately to get to proper values?
