Hello Everyone!
New member here and first time pool owner. This site is a miracle for a pool owner.
A little background.
I purchased a house in January with a 20x40 rectangular vinyl liner pool approximately 3 feet on the shallow end and 8 feet on the deep end. I am rough guessing 35k gallons of water. The pool has 3 return lines, two skimmers and main drain in the deep end. The drains are independent of each other and there is a separate valve at the pump to control each. A Hayward 1 1/2 horse power super pump and a Hayward s200 sand filter with a side mounted multi-port valve handle the maintenance duties.
From what i have been able to determine is the previous owner put in the plugs, covered the pool, drained the filter and called it a day. Since January I have been reading everything I can about owning a pool and maintaining it myself. After realizing all of the pool equipment left behind is broken I started buying things I knew I needed. A wall whale wash brush, ProTuff 23.5 skimmer net, Milliard manual vacuum head (there is a smart pool nc52s robot here but it has no bottom or leaf bag) and most importantly TF-100 test kit.
I pulled the cover off two days ago just to see what the condition of the pool was in while I waited until the TF-100 kit arrived(which it did today) The pool is green with leaves in the deep-end. The water level is right at the half way point of the skimmers. I have not turned on any of the equipment nor have I removed any plugs as I wanted see what the chemical readings are before I start.
Here are the results of those tests just now.
CYA=100(high)
TC = clear (I guess this means there is no chlorine at all in the pool.
PH= the color was yellow. Definitely lower than what the tester is able to read. It was more in line with the 2-4 range from the TC side of the tester.
Chlorine drop test = Also clear. More confirmation there is no chlorine in the pool
Calcium Hardness= 150 ppm. 6 drops of blue R-0012 were required. So 6x25
TA= went straight to red before I could add R-0009. Meaning PH is lower than or equal to 4.5
These numbers are so out of whack I don't know where to start. I have 4 gallons of 10% liquid chlorine from Wal-Mart but other than that no other chemicals. I am trying to plug everything into PoolMath.
Can someone please advise me on what I should do first to get started.
TIA
CYA=100(high)
TIA
