Greetings…
I have a question, and I have no idea if it is possible (within reason).
I have an inground pool that presently is setup for “pressure side”
2 pumps that must run simultaneously.
The filter system is a Sta Rite:
With the two pumps running a couple of hours each night, my current bill was $160 (month)
What I’d like to do, is change the system to a “suction side” system using an inteliflo (variable speed pump) and a “KreepyKrauly” or similar.
Where do I start, and what would I need to do?
Thanks in advance.
*Note to moderator….if this Post is not in the right spot, please move it to the right place.
Thank You!!
Sta-Rite 170145 Mod Media Replacement Cartridge Set for S7M120 Large and Small Cartridge Pack
The pool sweep is a Polaris 380:Polaris® Vac Sweep 380 Pressure Side In-ground Automatic Pool Cleaner
The swimming pool is at a home that is not occupied, my power provider is Southern California Edison.With the two pumps running a couple of hours each night, my current bill was $160 (month)
Thanks in advance.
Thank You!!
