Inground pool,inground problems!
Peggy Napier
1
Newport,Tennessee
I just moved into a house with a 35'x17',10' at the deep end. Beautiful pool area. The problem is I rent,landlord is leaving the pool to me. The piping is so old,someone poured concrete in the brain on the deep end. I believe they may have done the same to the skimmer area. The question is"can putting above piping work efficiently on a pool this deep? Help would be appreciated!!!!
Hey Peggy and Welcome !!!
Got pics ? With old plumbing the drain was likely abandoned at some point due to a leak. It very well could be fine.
Peggy,
Your pool will work just fine with the main drain plugged..
The skimmer must be working or your pump would not be able to circulate any water at all.
Please tell us why you think the skimmer is not working..
Several Pics of your equipment pad, would help us understand what you are up against..
