I'm looking for a solution to trigger a Pentair EasyTouch 8P-connected VSF pump turn-on when my infinity pool tank (basin) reaches a set high point. Current plan is to install a Zodiac/Jandy Levolor II K2000 hi/low water sensor controller. BUT, of course Jandy and Pentair products don't work together nice!!!
What I'm trying to do is: (assuming my infinity edge pump is off), I need to get the pump to turn on automatically for a set time when 2-3 people enter the pool. This displaces 60-100 gals, which raises the water in my submerged tank ~4 inches. Again, I'm trying to start an EasyTouch function based on a 'high water' sensor indication. (I'm not dealing with a low water level turn-on... we've go that working.)
In my current partially implemented solution, the Levolor K2000 controller sends a 24V signal (normally for a pump relay) when water reaches it's high sensor. The controller has smart features to lock-in the 24V turn-on for 5, 10, 30 etc so splashes or waves don't inadvertently turn-on the pump.
But in my case the VSF pump is controlled by a single-body EasyTouch 8p panel. It sends turn-on and speed control functions to the VSF pump via an RS232 interface.... there's no way to send an external 24V relay signal to the pump. Also, the EasyTouch 8P doesn't have a clear-cut input 'port' to take an external signal (particularly from a non-Pentair brand). And there is no Pentair high water sensor system out there - to my and my P/B's knowledge.
Any advice, tricks, or equipment options would be appreciated!!!
