Here's a quick run down of what I've done over the past 16 days. My pool was basically a swamp. It was left over from the previous owner and last year I tried, but failed, to complete a SLAM. It was too late in the season for me to continue and I had other priorities. Fast forward to this year and you can imagine what I had to start with. Checked the water and had a CYA of 20 and a pH of 8.2. I didn't read clearly that I shouldn't start the SLAM until my pH was down. Anyway, I have been dumping gallons and gallons of bleach in this pool and watching it disappear. I'm certain I had ammonia from all the leaves decomposing. The pool started to clear up but very cloudy. I scooped 4 big bags of dead leaves from the middle where they had collected after I whirlpooled for a while. It seemed as if I was making progress and the chlorine was not dropping as fast.... until yesterday. I was at 8 at 9am so I added another gallon of 10% bleach. I wasn't going to be home until late that evening so I had my daughter add another gallon for good measure at 1pm. When I checked at 11pm, I had ZERO FC. Sigh... talk about disheartening!!
Today, I'm thinking... ok, I gotta start over AGAIN... the pH was high so lets get this down to where it needs to be. I bought some muriatic acid and planned on getting this back in action again. The water is hardly green at all... more blueish but completely cloudy. Anyway, I test pH and I was FLOORED to see it was down in the 6's!!! What the heck?!?!?! I did a search here and found out that the reaction of bleach with the ammonia would cause the pH to drop. Sigh... ok. So, here's what I did tonight....
Added 2 gallons of 10% bleach
Turned my jet so that the water is sorta bubbling... not vigorously but a clear disruption on the surface.
Added 20 oz of some pH increaser I had from the previous owner.
Thoughts on where I go from here?
Oh... should I do a deep clean on my sand filter? I haven't done that yet and it seems as if I'm not getting much flow if I run the filter for a long period of time even though the pressure doesn't increase much.
Thanks!!
Geoff
Thanks!!
Geoff
