In-line Puck Chlorinator leaking at dial
tstex
2,236
Houston, TX
Hello to All,
I use the puck feeder only to add CYA as needed and a break from periodically pour CL.
I called CMP technical support but they didn’t even know their product. The dial that determines the flow rate (CW fully open, CCW, Closed) is dripping when it’s moved CW to dispense. If i shut it, CCW, dripping stops.
Inside the Dial Assembly, there’s an inner part and an o-ring, I’ve enclosed the link to my product and part # 11 is what i need.
I’ve enclosed 4 picks & link
1- overall pick of puck feeder w dial circled
2-dial area w arrow to leak
3-my dial online w no front tab to remove screw
4-dial w tab to remove screw to take off dial
My question is, how do I remove the dial so i can access o-ring to size up and replace?
Thank you very much
tstex
Here’s the other 2 pics..due to size, having to split btw 2 diff posts/ thank you
I thought you were getting a SWG?
Thanks James - I was but bc I am going to have to redo the equipment pad now and need shoulder surgery,, I wanted to wait until the temps are cooler and I'm fully ab le to do so...so for now, I want to plug this leak...thank you
AND PS James - you have a very good memory !! ;-)
Reactions: JamesW
Turn it off. Put tablets in floating chlorinator. No leak, chlorine and CYA added. $10.00
Reactions: Bperry and tstex
