I have wondered about this for a long time, because I only ever see leaves and debris stuck against one of the three covers. All three drains have Paramount SDX safety covers, and I wanted to see if there was a ton of junk underneath the covers, so I drained the tub and removed all 3 covers.
The one suctioning cover had tons of bark, seeds etc clogged in the underside of the grille, but the other two were pristine. I even blocked the suctioning drain with a small rubber ball, and the other two did not start suctioning at all, it just jammed up the pump. I changed the pump valves to try suctioning from the pool + tub together, and still those two drains did nothing.
Does anyone know why my hot tub would have two redundant drains?
