Thanks for the idea, looks pretty cool. Although it’s hard to believe there isn’t a way to install a permanent one after the decking is down. Hopefully I get some more inputI saw this style hoop on another poster’s pool (theirs was in ground) and after perusing the website I liked the Goaliath Junior Hoop. I will need to install it on maybe a large umbrella base so that I can maneuver it around the deck. I still haven’t figured out that part, yet.
Think that through. It needs to be connected from its location to an existing bond. They can't get under the existing concrete deck, and you can't lay the wire across the patio. If they used a saw to cut a small channel from A to B, they'd likely ruin your existing bond by hitting either the bonding wire itself or making the rebar no longer continuous. So they would create a much bigger problem by solving a basket ball problem.They said there is no way to do the bonding after the decking is installed. Am I missing something here? Would have to think it’s possible
I wish I understood electricity better but I don’t. How is sticking a metal pole in my concrete decking different from sticking a metal pole in concrete block on top of the decking different? From the perspective of why bonding is required.Think that through. It needs to be connected from its location to an existing bond. They can't get under the existing concrete deck, and you can't lay the wire across the patio. If they used a saw to cut a small channel from A to B, they'd likely ruin your existing bond by hitting either the bonding wire itself or making the rebar no longer continuous. So they would create a much bigger problem by solving a basket ball problem.
So. The basketball hoop has to.be 'Portable'
But there is lots of leeway as to what that means. You can pour yourself a honking concrete base and mount the fancy hoop in that. (Then jazz up the big block somehow, veneer stone maybe ?)
As far as electrons are concerned there is no difference. But as far as the written regulations, how they can be interpreted and the knowledge of people who think of them and the agendas of people who approve them, there could be a huge difference...How is sticking a metal pole in my concrete decking different from sticking a metal pole in concrete block on top of the decking different?
Dirt and sand would only help the hoop base make contact with the insulated concrete deck. Otherwise you'd have to bond every piece of patio furniture, deck boxes or anything reachable from in the pool also. They all have dirt under them too. Wood is mostly water so alot of furnature would conduct, especially when they are damp/wet. Anywho the point was that whatever it was needed to be above the deck and not through it like a ladder.Granted, it wouldn't be directly touching the earth, but give it a few weeks to collect some dirt and salt, and its conductive property would definitely increase.
Especially as it and the deck gets soaked. But then its connected through the deck bonding as it doesn't bypass the deck directly to earth ground.Otherwise, putting the metal post in a block (especially as the block becomes more and more electrically connected to the deck) would be just like putting the metal pole into the deck. No?
