That’s called a skim-coat. It’s the cheapest way to replaster a pool. It’s not the best as it only applies a very thin coat of new plaster. The risks are delamination if the new plaster doesn’t adhere well. A lot of people that don’t plan to own a home long will do that as it is a cheap way to refresh a pool surface for a home sale. Kind of like around here where the house painters will ask you if you want the forever-home coating (3 coats will a brush roll back) or the home-sale coating (watered-down paint sprayed on in two coats). The difference is a few thousand dollars.
It’s better to do a full chip out and replaster. If the company you contacted is unwilling to do that, then keep looking.
Any idea what the chip out costs? This is starting to really get costly because in addition to redoing the pool surface, I bought a new vs pool pump, and was looking to get a pool heater. And it costs $2000 to run 60a 80 foot to the rear of the house... $5000 for the sq150. Then it sounds like I should have the pool repaired before getting the new pump/heater installed. I'm starting to feel burned out.
Wouldn't removing the old plaster mean they need to add even more to replace it (over the quantity used for skim coat)? Is your 50% based on just the removal of the old plaster or does that account for additional materials? Or would the skimcoat use the same amount of materials either way?
Here's a pic of the pool's current condition. The pool guy said he thought I had another year or two life left on it. The reason for the rush is that there is a black spot forming which appears to be rebar starting to rust.
The 50% I’m guessing at but I would think that would cover the extra plaster thickness too. Most simple white plaster renovations with chip out are over $10k.
