- Mar 5, 2020
- 62
- Plaster
- CircuPool RJ-45 Plus
First-time homeowner for 2 months. My pool came with an SWCG. It hasn't appeared to work since I moved in, and since I didn't know anything about pools beforehand, I was relying on the inspector to diagnose this, but they missed it.
I had an electrician come by last Friday to help me with it and the rest of my pool wiring. We diagnosed that the 3A breaker inside the unit had failed and could not be reset. We tried turning on the unit after removing the failed breaker, but that tripped the 20A breaker on the main panel that controls both the SWCG and the filter pump (which should run at 10.8A but runs closer to 13A). He suggested that the SWCG might have a short in it.
This SWCG was installed in 2012, and the company whose name is on it (Nature Clear) is out of business. It's out of warranty, and the cells probably need to be replaced. (They are still available online.) I figured instead of trying to fix it, I should just replace it. I'll have more peace of mind with a popular, existing brand.
I read a few recent threads in this forum. I went through the list of SWCGs on discountsaltpool.com (DSP). I learned that I should try to get an SWCG that could supply a pool twice my size (18,000 x 2 = 36,000) for a margin of safety. I made a table comparing Circupool SWCGs with capacities over 1.5 lb/day. Circupool is the only brand I've seen recommended on this forum, and it is the brand with the highest "value scores" on DSP. I multipled the daily chlorine output by the warranty length to get a measure of the long-term capacity of each model, then divided that into the sale price (valid for 3 more days) to get a relative measure of the value of each unit. Am I far off in this?
I ended up choosing the RJ-45+ (rated capacity is for 45,000 gal pool). The RJ-60+ is an even better long-term value, but I suspect there are some parts that will wear out in time no matter how much you use the SWCG, which makes my value score less useful. The current sale is pretty good (about 20% off for my unit), so I pulled the trigger.
Pictured below is my current setup. I bought a vertical mounting kit because I don't have much horizontal room to splice an SWCG, and I thought it just might perfectly fit my existing configuration. Any mounting tips would be appreciated.
