New pool installed this year. We will be gone for an extended period of time after the pool is closed. I was concerned about torrential rain and or unusual snowfall and not being able to immediately pump the water off a cover or out of the sump tube if needed.
The salesman recommended a mesh cover. His reasoning was that any rain and snow melt would go thru the cover into the pool and since the skimmer and returns were sealed any excess would just run over the pool/deck and drain into the yard.
After further research about both types and talking with the guys that close the pools, I am considering having a solid cover installed. The consensus is that it will keep the pool cleaner and it is better to have any rain/snow melt pumped off the cover or allowed to run off the cover and onto the deck as opposed to overflowing the pool and on the deck.
How much water normally is held on the cover?
I understand pumping the water off is better sooner rather than later, it may be a few days before I could have someone pump it off when we are gone.
What about the snow, it could be weeks before it melts, and what if we get an unusual blizzard type event? I assume there is really nothing that can be done to prevent that if we are home or away.
