Hi there
I know this is a long shot but there are many folks here in Australia that use these forums so i thought posting a request here may be fruitful.
I have the above pump driven by a 1hp CMG motor. The pump hasn't been available for a few years but has worked perfectly for years. A couple of days ago I noticed the pump wasn't running (Im so used to the sound and the times it runs) so I went to investigate and the chlorinator light was on but the motor not running. I turned it off, unplugged it from the chlorinator and let it cool down, plugged it directly into the power point and then turned it on again to the sound of buzzing. Thinking it may have been the capacitor which I had spare I replaced it and had the same issue.
This morning I removed it from the pipework and pulled down the pump to find the impeller had come apart and jammed up the motor.
I've tried every avenue to get a replacement impeller (part number MK116415) with no luck so if anyone at all has a s/h Supa Jetflow pump gathering dust in their shed or a pump technician reading this has a either a new or s/h impeller they would like to sell I would be more than grateful.
Cheers
Cheers
