Hi Folks,
Numbers below via Taylor Kit; all checked and re-checked. Just finished 4-day SLAM.....and my pool is turning green, again.
I'm at my wit's end; have been following the TFP process, I know a couple of my numbers are not quite perfect, but with the overall high levels of chlorine I've just submitted my pool to I am frustrated to be constantly fighting algae.
Small film of green dust on pool floor; I can get the water looking great at times, but generally for only about 5 days before I'm fighting algae.
I'm beginning to suspect my filter is undersized. Any advice appreciated!!
FC 6 (3 days after 4-day SLAM process. All liquid Chlorine)
pH 7.5
TA 100 (Slightly on high side. Can adjust w Muriatic Acid)
CH 400
CYA 56 (Was 110 three weeks ago; fired company who used only trichlor pucks for 4 months. Drained approx 33% and am only using liquid chlorine until I achieve 35 or so, then will toss an occasional puck in as CYA is needed.)
Small pool, 5500 gallons
Thanks in advance!
pH 7.5
CH 400
Thanks in advance!
