- Jul 26, 2020
- 246
- Plaster
- Jandy Aquapure 1400
That’s a good idea on calling a local yard and seeing how much fieldstone is to cover approx 250sq ftNice Pool design.. I really like free form pools, and free form spas are rare.. they are usually just round. I cant believe I missed your thread as well.
It should be easy to call a materials yard, one that sells that type of stone and ask them how much 250 sqft of stone in that type is.. So is he charging you more for the extra masonry work as well? They must have a rough per sqft rate, that doesn't include setup time.
Also I would have spaced the equipment pad out from the house wall more. Give your self more room to work back there in case you need to service something... AND as Kimkats implied.. less noise for whatever is on the other side of that window.
I don’t even know if that’s a real # or what they just are telling me
You can see from the pics that the stone work is a lot and hard to tell from the CAD drawing how high the perimeter wall really is it was supposed to be abs the extra coverage needed for the stairs
so when the contract says “vaneer wall” there are a lot of assumptions in the
equipment pad:
Good point on next to wall - luckily this is a furnished basement albeit we use it regularly it is no bedroom
Think they tucked it in because the gate swings in front of it and they tried to maintain the existing plant bed line
it’s done now so not much I can do to bring it out 6” I don’t think - wish I thought of it prior and gave them direction
thanks for your response and insights
