I bought my house 26 years ago with an inground pool. Knew nothing about it. The seller used a mesh winter cover and water bags so I just went along with it since then. I have always wondered why there was so much less water in the pool when I opened it in the spring. I assumed that some water has to come up through the cover in areas of holes and/or tears and I have always been pretty diligent in inspecting the cover in the spring and repairing any obvious defects. But I never thought the whole cover was porous!! I did a Google search and read that they are indeed porous. If fact, I covered the pool last week but the cover was too taught so I rolled off the bags and gently pushed the cover down along the edges. To my surprise, almost every time my fingers pushed the cover below the water line, water came up through the mesh. The cover is about 3 years old. Can't replace it every 2 years, can you? I've always been pretty pro-active in pumping the water off the top of the cover, so what it seems I have been doing forever is just draining the water out of my pool! So, what's the point of these mesh covers? It seems I can't pump the water off because new water from underneath seeps through to replace it, especially in the area of the pump which pushes the mesh down. And spring has always been misery also. Even when I think I have almost all the water off and let it dry on a sunny day, by the time I am trying to remove those last 5 feet, the cover is loaded with water and not manageable. Is this par for the course with a mesh cover? Am I supposed to replace it every year? how to you people out there handle this?
Thanks, Dave
Thanks, Dave
