I am switching to a VS pump from my two speed in a couple of months. I will open up the valve then. I really appreciate your help. I will post what I discover.Have you opened up the check valve to confirm that the spring and flapper are moving properly? Use a screwdriver, no power tools on the screws.
While you have the valve open you can turn on the pump and change the valves and see when water gushes out of the hole. That will let you understand when water is flowing down that pipe.
I did notice last night that the check valve spiked for a split second, but didn’t connect the dots. Could the check valve be bad as opposed to the line blocked?If you put the "OFF" part of the valve at the red lines, you can verify the function of each line.
The green line is the flow.
Watch the filter pressure for each configuration to make sure that it is about the same for each configuration.
If it spikes on Configuration 3, the line is probably blocked. Turn off the pump right away to avoid problems.
_________________________________________________________________
Configuration 1.
All Flow to Line 1.
Configuration 2.
All Flow to Line 2.
Configuration 3.
All Flow to Line 3.
Possibly.Could the check valve be bad as opposed to the line blocked?
We are in a mini freeze spell at the moment. Once it warms up, I definitely will try. I can’t help but assume that all is working as it should because my spa / pool levels are functioning properly as the freeze protection cycle from pool to spa.Possibly.
Try Configuration 1 and 2 to verify the function of lines 1 and 2.
You can try Configuration 3 with the pump on low and then high, but if the line is blocked, then you can get high pressure on the filter but it should not exceed the filter pressure rating.
If the pressure spikes up on Configuration 3, turn the pump off immediately.
The pump can reach a maximum of about 37.5 psi, which is more than the pressure test limit, but not more than the working pressure limit.
Both are wall returns with multiple adjustable eyeballs.Line 1 and line 2 have to go to the Pool and not the Spa because they do not have a check valve.
Without a check valve, the Spa would drain into the pool through the plumbing.
The Spa Lines have a check valve.
The Pool Lines do not have a check valve.
Can you describe the returns in the Pool and in the Spa?
I don't think so.Line 1 definitely controls the spa bubbler.
OK. I shut off Line 1. You were absolutely correct. The pool wall returns shut off. I did this on low speed, then went to high speed. The flow on spa spillway sped up. Dropped it down to low speed and shut off both lines then went to high speed. The flow on the spa spillway went wild, you’d think the blower was on, the water flow was even faster over the spillway. However, that check valve did not open and the spa bubbler stayed on in both conditions.I don't think so.
I think that Line 1 is the pool wall returns.
I think that Line 2 is Pool Bubblers.
What does the writing say on line 1 and Line 2?
Line 3 is a Spa Bubbler.
The far left line is Spa Wall Returns.
If both of the lines are closed, then the check valve has to be open.However, that check valve did not open and the spa bubbler stayed on in both conditions.
