I need to put up a picture but right now I don't have one so hopefully this makes sense. Anyhow I have my pool pipes dug up (I replaced them) and need to back fill in the area, rock, concrete etc. The one thing I noticed throughout the winter was the area around my pool always filling up with water after a rain. Tons of water... it would nearly tops off to the pool edge. I have a sump down inside the channeled area so after it rains I pump it all out. But then a few hours later it's partly filled again. After repeating this cycle several times it will finally stay empty, that is until the rain comes again.
So it's probably not shocking to know whats going on. A small stream emerges once I empty the area. The trickling of water comes from only one area that I channeled back to my patio. The rest is surrounded by thick clay so I am assuming it blocks it out. Prior to digging that particular area was also compacted clay that sat under the patio area that I had cut out. The same area is closest to my hill side, so I am going to assume all of the built up ground water finds it way out via the channel I dug towards it.
(sorry long winded)
My question is what should I do about this? I was going to back fill the entire area with the recommended rock I got from here but that obviously will just allow the water to flow right in around my pool. Do you guys think there is some way to dam this off, possibly by compacting clay into the channel? It's freaking me out a bit as I need to get this all finished up but it's worrisome.
Thanks!
(sorry long winded)
Thanks!
