Hi All,
I feel like between the pool builders and their recommended "pool guy" all they were interested in was collecting the cash but not setting things up.
We live in South Florida and our pool is 14k gallons which includes a spa. We have a Jandy TruClear SG, a Jandy VS FloPro 230v 1.65HP variable speed pump and everything is controlled through the iAqualink.
The SWG is currently set at 40% which seems to be producing the right amount of chlorine for the pool.
The run times are M-F 11:00am - 4:00pm and Weekend 6:00am - 6:00pm.
When I look at the speeds the pump is set at I have the following:
Pool - 3450
Pool Heat - 3450
Spa - 3450
Spa Heat - 3450
Speed 3 - 2750
Speed 4 - 2750
Speed 7 - 2750
In Floor - 2750
I think 3450 is the max speed.
I feel like nothing was setup correctly and we're really not using the variable speed pump the way it should be used.
What would the ideal and recommended run times be for our pool and what should the variable speeds be set at?
Thanks everyone
Pool - 3450
Pool Heat - 3450
Spa - 3450
Spa Heat - 3450
Speed 3 - 2750
Speed 4 - 2750
Speed 7 - 2750
In Floor - 2750
Thanks everyone
