Ichlor and Screenlogic2 question
Sep 27, 2018
1
LOXAHATCHEE
Good morning. I have a newly renovated 15K pool with all new Pentair equipment including the Easy Touch PSL4 panel. The pool has ran for a month and this week all the chems were added and the Ichlor was started up. I have communication between the panel and screenlogic however, the Ichlor can't seem to be controlled by the screenlogic. Everything on the Ichlor rests to zero when I try to adjust it on screenlogic so I have to physically go out to the Ichlor and make changes there. The pump, lights and water features can still be controlled through screenlogic. Any suggestions?
Mb,
Since you have the lite version of the EasyTouch, this means you must have an external power center..
Most likely the idiot that installed your system, did not wire the com port of the Power Center into the EasyTouch like you need to do..
If they made that mistake, then I need to ask... Does your cell only get power when the pump is running? If not, the cell can explode. Does not happen often, but it can happen. The AC power to the cell's Power Center, MUST come from the load side of the Pump/Filter relay.
Reactions: BowserB
