Hi,
I was getting inaccurate readings on my IC30, specifically very high water temperature and salt readings that were all over the place. I've seen this can typically be a faulty flow switch on these units so I replaced it a few days ago. It's working again, but the readings are still all over the place and now it thinks the salt is low again so it's not producing chlorine. (Salt is in the 3500 range determined by both a pool store water test and a home test) My initial thought now is to do a factory reset to clear the memory and allow it to start using the new flow switch from scratch, could that be a start? Problem with that is when I hold down "more" for 10 seconds to initiate the reset nothing happens besides diagnostic mode...
